alexd912 Posted June 30, 2018 Posted June 30, 2018 Hey, I have a 1965 Kupla with the windscreen rubber that has the aluminium filler strip and I need to find a new rubber. My sprayer has suggested that I buy one from Germany as the one made from Brazil did not fit correctly at the . corners and the filler did not fit. Is there anywhere in Finland that I can buy one. Kiitos Alex Quote
jarkki86 Posted June 30, 2018 Posted June 30, 2018 If i remember correctly, i bought this one. First it looked that the corners won't fit but after some "rubbing" it fitted fine. http://www.aircooled.fi/tuote/6312/tuulilasin-tiiviste-listaura-alumiinilistalle-t1-864779-1laatu-ww Quote
alexd912 Posted June 30, 2018 Author Posted June 30, 2018 Hey Jarkki86, I have seen this make advertised a few times. Can you remember if it had the moulded edges for the corners? I found this in Germany but expensive with delivery. http://www.vwkaeferersatzteile.de/Verglasung/Dichtungen-Leisten/Frontscheibe/Vorgeformte-Dichtungen-Frontscheibe-Deluxe::457.html It seems, but I am no expert, but some come as a straight piece of rubber, others are made to fit in one piece. Thanks for replying it is very appreciated. Alex Quote
jarkki86 Posted June 30, 2018 Posted June 30, 2018 I really can't remember were the corners moulded but my wife also remembered that the rubber was relatively easy to install. I think we used a small hook to "flip" the cornes to fit. I think that user "jeeves" can give you the answer, he works in that store. Quote
