alexd912 Posted June 30, 2018 Share Posted June 30, 2018 Hey, I have a 1965 Kupla with the windscreen rubber that has the aluminium filler strip and I need to find a new rubber. My sprayer has suggested that I buy one from Germany as the one made from Brazil did not fit correctly at the . corners and the filler did not fit. Is there anywhere in Finland that I can buy one. Kiitos Alex Quote Link to comment
jarkki86 Posted June 30, 2018 Share Posted June 30, 2018 If i remember correctly, i bought this one. First it looked that the corners won't fit but after some "rubbing" it fitted fine. http://www.aircooled.fi/tuote/6312/tuulilasin-tiiviste-listaura-alumiinilistalle-t1-864779-1laatu-ww Quote Link to comment
alexd912 Posted June 30, 2018 Author Share Posted June 30, 2018 Hey Jarkki86, I have seen this make advertised a few times. Can you remember if it had the moulded edges for the corners? I found this in Germany but expensive with delivery. http://www.vwkaeferersatzteile.de/Verglasung/Dichtungen-Leisten/Frontscheibe/Vorgeformte-Dichtungen-Frontscheibe-Deluxe::457.html It seems, but I am no expert, but some come as a straight piece of rubber, others are made to fit in one piece. Thanks for replying it is very appreciated. Alex Quote Link to comment
jarkki86 Posted June 30, 2018 Share Posted June 30, 2018 I really can't remember were the corners moulded but my wife also remembered that the rubber was relatively easy to install. I think we used a small hook to "flip" the cornes to fit. I think that user "jeeves" can give you the answer, he works in that store. Quote Link to comment
