85.5 männän korkeus?
Guest Bugfuel
Kympin matalammaksi ilmoittaa keijo.
GB 002 85.5mm cast aluminium pistons are manufactured by the original VW suppliers; Mahle, KS, Cima or Cofap. For stock replacement. These will not clear any counterweighted crankshaft without skirt clearancing. If using a counterweighted crankshaft use GB 002F or see LA PST016-4. (39.6mm pin height), case 90mm, head 93.8mm.
