alexd912 Posted September 29, 2018 Posted September 29, 2018 Hi all, I have a 65 Kupla and when turning the steering full lock the tyre will rub on the wheel arch. The 65 does not have the traditional steering stop bolt adjuster on the front beam as late ones that prevent the movement of the steering arm. I read somewhere it is in the brake drum (some 3 bolts) but I cant find any reference or pictures anywhere or even sure which side it would be on. Kiitos Alex Quote
metake Posted September 29, 2018 Posted September 29, 2018 -65 bug has not adjustable steering stops. They are fixed located nearby king pin.Sent from my iPhone using Tapatalk Quote
DOODAH Posted October 1, 2018 Posted October 1, 2018 yap. But longer bolt change to brakeplate fitting works in this prob ok. You must take brake drum of to find these bolts. Quote
alexd912 Posted October 1, 2018 Author Posted October 1, 2018 Kiitos guys. I wonder why mine has started to rub? Does this mean something has come out of alignment? Thanks DOODAH for that tip. I suppose its quite obvious which bolt to change. Do I need any special tools to take the brake drum off? Thanks again for your help guys. Alex Quote
Tanhis Posted October 2, 2018 Posted October 2, 2018 (edited) If your brake adjusters work then you don't need a drum puller, or any other special tools to pull the drum off. Edited October 2, 2018 by Tanhis Quote
mikan Posted October 2, 2018 Posted October 2, 2018 Narrowed front axle or rims with a different offset than standard? r. Mika Quote
